House Raelian Touring
Salve a tutti Re-Voltiani ho aperto questo topic per pubblicizzare le mie auto (dato che sono le mie prime "creazioni") e per sapere un vostro parere, sto parlando dei Repaint/Repam:
Hummacclaim --> http://www.aliasrevoltmaster.com/portal ... le_id=1074
Hummacclaim GT --> http://www.aliasrevoltmaster.com/portal ... le_id=1075
AzaZel --> http://www.aliasrevoltmaster.com/portal ... le_id=1160
Humma HRT --> http://www.aliasrevoltmaster.com/portal ... le_id=1076
Super HRT Prototype --> http://www.aliasrevoltmaster.com/portal ... le_id=1082
Z-HRT --> http://www.aliasrevoltmaster.com/portal ... le_id=1090
Z-HRT GOLDEN --> http://www.aliasrevoltmaster.com/portal ... le_id=1091
Z-HRT PLATINUM --> http://www.aliasrevoltmaster.com/portal ... le_id=1134
Steel Cougar --> http://www.aliasrevoltmaster.com/portal ... le_id=1177
Z-HRT SPECIAL OSMIUM EDITION --> http://www.aliasrevoltmaster.com/portal ... le_id=1135
Z-HRT TANK --> http://www.aliasrevoltmaster.com/portal ... le_id=1169
Baal Shamem --> http://www.aliasrevoltmaster.com/portal ... le_id=1196
Black Teapot --> http://www.aliasrevoltmaster.com/portal ... le_id=1198
Bricks Block --> http://www.aliasrevoltmaster.com/portal ... le_id=1204
EViL Z-HRT Tank --> http://www.aliasrevoltmaster.com/portal ... le_id=1206
Evil Humma --> http://www.aliasrevoltmaster.com/portal ... le_id=1199
OVER --> http://www.aliasrevoltmaster.com/portal ... le_id=1195
Boss's H.R.T. Car --> http://www.aliasrevoltmaster.com/portal ... le_id=1099
Carbon Pollution --> http://www.aliasrevoltmaster.com/portal ... le_id=1230
Over Drag OP-MR --> http://www.aliasrevoltmaster.com/portal ... le_id=1231
SMW 35 --> http://www.aliasrevoltmaster.com/portal ... le_id=1232
Mystery Car [RV2] --> http://www.aliasrevoltmaster.com/portal ... le_id=1233
Eco-Logic Feather --> http://www.aliasrevoltmaster.com/portal ... le_id=1207
The Zipper Re-Volt Family --> http://www.aliasrevoltmaster.com/portal ... le_id=1359
RC Super One --> http://www.aliasrevoltmaster.com/portal ... le_id=1351
__________________________________________________________________________________________
Lunga vita ai Re-Voltiani !!!!!!!!
PS: Michelangelo dimmi che ho messo il topic nella sezione giusta...
Ultima modifica di RAELiAN il sab 14 ott 2017, 3:30, modificato 9 volte in totale.
ARM CARD
ARM CARD
Re: House Raelian Touring
E' più giusto metterlo in questa sezione dato che stai pubblicizzando alcune tue creazioni, ma non ti preoccupare per lo sbaglio!RAELiAN ha scritto:PS: Michelangelo dimmi che ho messo il topic nella sezione giusta...
La prima è molto bella, mi piacciono le gomme nuove e complimenti per lo stile. A me piace la Humma, sebbene la prima volta non mi abbia fatto molto piacere guidarla
Provale tutte e dammi un parereBrunilde ha scritto:La prima è molto bella, mi piacciono le gomme nuove e complimenti per lo stile. A me piace la Humma, sebbene la prima volta non mi abbia fatto molto piacere guidarla
ARM CARD
ARM CARD
Ho notato le nuove Z-HRT fatte in altri 'metalli'... Mi incuriosisce quella di 1 tonnellata (costruita in osmio, mi pare) e credo che la proverò anche perché mi ricordo che sulla primissima (quella effetto alluminio a 'chicchi di riso') avevamo collaborato per i parametri.
Comunque un suggerimento... Onestamente se fossi in te io lascerei i vetri e altri dettagli della carrozzeria (fari, griglie eccetera), perché così come sono quei repaint sembrano un po'... Troppo poco professionali diciamo... Capisci cosa intendo? Mi spiego meglio: le tue Humma al contrario, pur essendo repaint tecnicamente più semplici dal punto di vista prettamente della realizzazione, sono comunque più 'autentiche' da un punto di vista estetico...
E farei anche un'altra cosa: userei cerchi a risoluzione più elevata, quelli che hai su adesso (specie sulla Z-HRT originale) sono abbastanza sgranati... Però quelli della Golden Edition ci stanno piuttosto bene
Se vuoi dei cerchi, io so dove trovartene a palate comunque, basta che mi chiedi xD
Grazie Burner il fatto di non aver lasciato i vetri è una scelta perché l idea è comunque di un auto che dia l impressione di un incudine a 4 ruote ... immaginati un blocco di metallo pesantissimo e leggermente modellato a 4 ruote . Per i cerchi non saprei come fare sono ancora a livelli di realizzazione e di editing abbastanza bassi... le idee ci sono ma le mie capacità mi limitano nella realizzazione comunque se vuoi sarei molto felice di un paio di treni di gomme nuovi grazie mille Burnerburner94 ha scritto:Ho notato le nuove Z-HRT fatte in altri 'metalli'... Mi incuriosisce quella di 1 tonnellata (costruita in osmio, mi pare) e credo che la proverò anche perché mi ricordo che sulla primissima (quella effetto alluminio a 'chicchi di riso') avevamo collaborato per i parametri.
EDIT: la Z-HRT Osmium è stata un bel casino nel caso dell inerzia anche perché le ruote non avrebbero mai retto xD
Ultima modifica di RAELiAN il mar 25 feb 2014, 22:12, modificato 1 volta in totale.
ARM CARD
ARM CARD
Ma scusa, copiaincollare direttamente una foto di un cerchio? Ce ne sono a quintalate su internet, basta cercarne una 'dritta' (cioè il cerchio dev'essere fotografato di fronte, non inclinato) con il motivo che ti piace, e poi la adatti semplicemente alla forma che deve avere sul bmp (occhio alle trasparenze, elimina tutto il nero puro che riesci a trovare). Facile no? xDRAELiAN ha scritto:Per i cerchi non saprei come fare sono ancora a livelli di realizzazione e di editing abbastanza bassi...
Ho terminato finalmente TUTTI gli aggiornamenti di ogni singolo REPAM...
Hummacclaim HRT --> http://www.aliasrevoltmaster.com/portal ... le_id=1162
Z-HRT Cars PACK (pacchetto contenente tutte le Z-HRT) --> http://www.aliasrevoltmaster.com/portal ... le_id=1168
ARM CARD
ARM CARD
Ed ecco qui il mio regalo di natale per tutti voi ARMiani
ARM CARD
ARM CARD
Grazie per il regalo!
Cattivamente Natalizia! Grazie!!!
La volevo lanciare per capodanno ma siccome è pronta eccola qua
ARM CARD
ARM CARD
Graficamente è carina, ma alla fin fine di parametri è molto simile alla Carbon Porche che frantumò i record di velocità, anzi, inizio a sospettare che effettivamente i parametri sono gli stessi con la TopSpeed limitata, ma comunque bel lavoro
Si ovviamente la maggior parte dei parametri è rimasta come d' origine... ciò che ho effettivamente modificato sono: ombra riadattata, velocità limitata a 33 mph, aggiunta statistiche, aggiunta carbox, modifica ruote tra cui accelerazione grip e peso, velocità di risposta dello sterzo e del controsterzo, aggiunta antenna e posizionamento di essa, peso complessivo dell auto portato a 1,8 Kg , modifica inerzia, aumentata la deportanza, modificata la resistenza d'aria angolare (sia in aria che a terra) , lieve modifica alla posizione centrale del peso, modifica della frizione delle ruote anteriori, colore riflessi da bianco a rosso... e basta l' intelligenza artificiale l'ho lasciata com'era (abbastanza perfetta) per il resto è uguale alla Carbon Porsche GT1ciccio ha scritto:Graficamente è carina, ma alla fin fine di parametri è molto simile alla Carbon Porche che frantumò i record di velocità, anzi, inizio a sospettare che effettivamente i parametri sono gli stessi con la TopSpeed limitata, ma comunque bel lavoro
ARM CARD
ARM CARD
Ho aggiornato il mio regalo di natale leggermente più guidabile di prima... mi sono reso conto che veniva battuta addirittura da ADEONRAELiAN ha scritto:Ed ecco qui il mio regalo di natale per tutti voi ARMiani
ARM CARD
ARM CARD
