Hello
I created this topic for those who have concerns about re-volt & RVGL ...
For my part, I have some ...
- Or put the models download from your site, there's no indication in your
archive.
http://www.aliasrevoltmaster.com/portal ... &cat_id=13
- I duplicate Panga, but the problem is that it does not move when you turn, how to fix it?
Thank you
Topic Helping from Re-Volt & RVGL
- Black Re-Volt
I'm not English, but French.
Je suis pas Anglais, mais Français.
Re: Topic Helping from Re-Volt & RVGL
Hi.
I am not sure that I understood well.
You have create a copy of Panga... but a simple copy-paste is not enough to have the head turning with the steer (that is your problem, isn't it?)
There are new parameters, added in Re-Volt 1.2 and RVGL, needed to have this effect... i suggest you to look at the RVGL changelog.txt. Or, in alternative, take a look at the parameters.txt from one of our KKC Karts
I didn't understand what are you asking about the models. However, that models are PRMs that you can put in your track directory in order to add them to your track via MIG.
- Black Re-Volt
Yeah, but to move his head to Panga, I'm not good at English
But for the models, does it create a custom folder in the level folder of the circuit or replace it with an existing model of the model folder?
Ultima modifica di Black Re-Volt il dom 15 apr 2018, 12:11, modificato 1 volta in totale.
