Good evening
I have a problem with this vehicle.
http://www.aliasrevoltmaster.com/portal ... le_id=1176
When I put it in the cars folder, the vehicle is present in the game.
but as soon as I modify something in the parameter.txt, the vehicle is no longer in the game, even by entering it
Solution :
The problem was with the parameters.txt file
To correct this:
1: Creates a text document in the car file.
2: Open the original parameters file of the car
3: Copy all the text from the car and then paste it into the new text document.
4: Delete the original car parameter.
5: Rename New text documents to parameter.
[Resolved] Car problem Fiddler
- Black Re-Volt
Ultima modifica di Black Re-Volt il gio 12 ott 2017, 14:08, modificato 1 volta in totale.
I'm not English, but French.
Je suis pas Anglais, mais Français.
Re: [Resolved] Car problem Fiddler
If you want to see the real statistics of that car download this parameters file version --> http://www.aliasrevoltmaster.com/portal ... le_id=1221 EnjoyBlack Re-Volt ha scritto:Good evening
Solution :
To correct this:
ARM CARD
ARM CARD
- Black Re-Volt
folder failedRAELiAN ha scritto:If you want to see the real statistics of that car download this parameters file version --> http://www.aliasrevoltmaster.com/portal ... le_id=1221 EnjoyBlack Re-Volt ha scritto:Good evening
Solution :
To correct this:
