Cambiare il colore delle ombre file .prm
Maximvs
Messaggio da Maximvs » gio 25 lug 2013, 11:21
Vi posto un pezzo di codice per modificare il colore delle ombre nei file .prm, spero che possa servire a chi vuole sperimentare
Codice VB
Public Class Form1
    Structure DCol
        Dim R As Integer
        Dim G As Integer
        Dim B As Integer
    End Structure
    Dim ColoreSel As DCol
    Private Sub PictureBox1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PictureBox1.Click
        Dim ApriColore As New ColorDialog()
        ApriColore.ShowDialog()
        PictureBox1.BackColor = ApriColore.Color
        ColoreSel.R = ApriColore.Color.R
        ColoreSel.G = ApriColore.Color.G
        ColoreSel.B = ApriColore.Color.B
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim RicercaConclusa As Boolean = False
        Dim i As Integer
        Dim ApriFile As New OpenFileDialog()
        ApriFile.Filter = "Mesh Re-Volt(*.prm)|*.prm"
        If ApriFile.ShowDialog() = DialogResult.Cancel Then
            MsgBox("Non hai selezionato nessun file", vbExclamation, "Messaggio")
            Exit Sub
        End If
        Dim FileArray() As Byte = My.Computer.FileSystem.ReadAllBytes(ApriFile.FileName)
        Dim StopRicerca As Integer = (BitConverter.ToInt16(FileArray, 0)) * 60
        For x = 16 To StopRicerca Step 60
            For k = 0 To 8 Step 4
                FileArray(x + k) = ColoreSel.B
                FileArray(x + k + 1) = ColoreSel.G
                FileArray(x + k + 2) = ColoreSel.R
            Next k
        Next x
        My.Computer.FileSystem.WriteAllBytes(ApriFile.FileName, FileArray, False)
        MsgBox("File scritto con successo", vbInformation, "Scrittura")
    End Sub
End Class
Qui il Codice C#
using System;
using System.Windows.Forms;
using System.IO;
namespace WindowsFormsApplication1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        struct ColoreRGB
            public byte R;
            public byte G;
            public byte B;
        ColoreRGB ColoreSel;
        private void pictureBox1_Click(object sender, EventArgs e)
            ColorDialog ApriColore = new ColorDialog();
            ApriColore.ShowDialog();
            pictureBox1.BackColor = ApriColore.Color;
            ColoreSel.R = ApriColore.Color.R;
            ColoreSel.G = ApriColore.Color.G;
            ColoreSel.B = ApriColore.Color.B;
        private void button1_Click(object sender, EventArgs e)
            bool RicercaConclusa=false;
            int i;
            byte[] FileArray;
            OpenFileDialog ApriFile = new OpenFileDialog();
            ApriFile.Filter = "Mesh Re-Volt(*.prm)|*.prm";
            if (ApriFile.ShowDialog(this)==DialogResult.Cancel)
                MessageBox.Show("Non hai selezionato nessun file","Messaggio",MessageBoxButtons.OK ,MessageBoxIcon.Exclamation);
                return;
            FileArray = File.ReadAllBytes(ApriFile.FileName);
            for (i = FileArray.Length -1 ; i > 0; i--)
			    for (int x=0; x<=7;x++)
                    if (FileArray[i-x]!=0) break;
                    if (x == 7) RicercaConclusa = true;
                if (RicercaConclusa == true) break;
            for (int x = 16; x < i; x = x + 60)
                for (int k=0;k<=8;k=k+4)
                    FileArray[x + k] =  ColoreSel.B;
                    FileArray[x + k + 1] = ColoreSel.G;
                    FileArray[x + k + 2] = ColoreSel.R;
            File.WriteAllBytes(ApriFile.FileName,FileArray);
            MessageBox.Show("File scritto con successo","Scrittura",MessageBoxButtons.OK ,MessageBoxIcon.Information );
Ultima modifica di Maximvs il gio 25 lug 2013, 17:28, modificato 2 volte in totale.
Re: Cambiare il colore delle ombre file .prm
Messaggio da TheFactor82 » gio 25 lug 2013, 13:38
Ma io mi chiedo: mi sti codici, dove van messi? Come vanno usati???
:dubbi: :-?
Maximvs
Messaggio da Maximvs » gio 25 lug 2013, 13:57
il codice che ho scritto è VB .net se vuoi ti mando i due eseguibili che ho fatto fin ora adesso stavo lavorando su un 3° Codice che serve per convertire da .3ds a .prm, ho postato questi 2 pezzettini minuscoli di codice per far si che chi vuole li può usare in qualche applicazione lol
Ho scritto anche il codice in C# :imp:
Ultima modifica di Maximvs il gio 25 lug 2013, 15:30, modificato 1 volta in totale.
