nVolt and KDL's tools for track making
KayTheFalcon
Messaggio da KayTheFalcon » gio 22 mar 2012, 20:57
Hello everybody ^^ It has been a long time
So today I'm going to present a small program named nVolt (which is a prm/w viewer) based on Irrlicht.NET (analogous to FreeVolts' Irrlicht / C++)
How to use it
1. by drag and drop Re-Volt levels and cars' folders
2. by drag and drop .prm and .w files
3. making it the 'default file opener of prm and w files'
Download link
screenshot:
Google translation:
Ciao a tutti ^ ^ E 'stato un lungo periodo di tempo
Così oggi ho intenzione di presentare un piccolo programma chiamato nVolt (che è un prm / w viewer) sulla base Irrlicht.NET (analogo a Irrlicht FreeVolts dei / C + +)
Come si usa[/ u]
1. con il drag and drop Re-Volt livelli e cartelle vetture
2. con il drag and drop. PRM e file w
3. diventando così il 'apri file predefinito di file PRM e w'
W_Console:
a small tool for:
- creating texture animation
- assign colors for ENV
Download latest
Download version before the latest (contains help files)
* How to make animation:
pick work
and select a world file (the other way:
load C:\path\to\worldfile.w
getbytex B:list
: list all meshes with B bitmap
select 17
: select mesh n°17
preview
: to preview mesh in nVolt or freevolts (extract nVolt to yourdocuments\nvolt\ or freevolts to C:\windows\ )
generate framelist
: generate a simple frame list, then modify it it's in level directory just write "explore" and you'll find it
pick texanim
: pick frame list
the other way using Texanimgenerator: (open both of w_console and texanimgenerator)
write
sync
then modify values in texanimgen and press button "sync" and the texanim will be loaded
convert quads
convert current mesh to quad (instead of tris exported by 3Ds max as ase)
animate
: to animate current mesh using the loaded
revolt
to launch Re-Volt in window/dev mode
Best regards!
Ultima modifica di KayTheFalcon il ven 23 mar 2012, 13:19, modificato 2 volte in totale.
Re: nVolt and KDL's tools for track making
Messaggio da Piereligio » ven 23 mar 2012, 10:27
That's awesome! I will download it!
È fantastico! Lo scaricherò!
Messaggio da TheFactor82 » ven 23 mar 2012, 11:30
Kay, link to "Download latest" is an image... Where can we download the latest version?
(Kay, il link per l'ultima versione punta ad un'immagine... Da dove possiamo scaricare l'ultima versione?)
KayTheFalcon
Messaggio da KayTheFalcon » ven 23 mar 2012, 13:19
Sorry, I'll be fixing it ^^
Crescviper
Messaggio da Crescviper » ven 23 mar 2012, 23:05
Thank you very much mate!!! This program is really awesome :sbav:
Messaggio da TheFactor82 » sab 24 mar 2012, 12:07
All tools added on ALIASREVOLTMASTER - DOWNLOADS section! :-)
(Tutti i programmi disponibili nella sezione downloads di ARM)
Messaggio da Vas0sky » dom 10 giu 2012, 10:41
sinceramente raga... io non ho ancora capito come funziona...
