CONFERMO CHE IL MULTIPLAYER FUNZIONA !!!
Come da immagine allegata, il programma in questione funziona e in qualche modo aggira il bug del directplay. Sto giocando con molta soddisfazione ....
L'unica cosa da fare:
1) Impostare la compatibilita Win98 / Me sulleseguibile di revolt facendo click col destro, proprieta - compatibilita - SPUNTARE esegui compatibilita per Win98 / Me
2) Se avete winXp, installate l'ultima patch e sopratutto se avete una versione Twilight o quantomeno non installabile (semplicemente scompattata dentro una cartella) mettetela sul desktop altrimenti non lancia il gioco in automatico.....
Per il resto sto ancora testando...
Setteggi Firewall / Router
Router/Firewall Help
If you have a router and/or firewall you must configure them so that you can use RV House and play Re-Volt online.
To make things as clear and easy as possible the recommendations are here divided to instructions for routers and separate instructions for firewalls. If you have both a router and a firewall, apply both instructions.
Router
If you have a router you must forward some ports to your own computer. From your router configuration try finding something named similarly to "Port Forwarding". Then configure there it to forward the ports according to the following table:
Router Port Forwarding table: Protocol Source Ports Target Ports From IP To IP
TCP 2301,47624 2301,47624 ALL Your IP
UDP 2300-2400 2300-2400 ALL Your IP
Also see Port Forward web-site's "Forwarding" section if you have trouble finding the right settings for your router. You can for example select eDonkey application and by similar procedure apply the settings outlined above to your router.
Firewall
The easiest thing to do is to set firewall to allow making all connections for Re-Volt and RV House. If that is not possible for some reason, here is how you should setup the ports:
Firewall settings: Protocol Ports Source/Target Direction
UDP/TCP ALL Target out
UDP 2300-2400 Source/Target in/out
TCP 47624 Source/Target in/out
